Hello
I am trying to use the tool Make Query Layer (Data Management) but every time it returns an empty layer. I am able to successfully create the query layer by going to Map - Add Data - Query Layer. In both situations, I am using the same SDE database connection, same feature class and table, and same exact query expression.
select a.OBJECTID, a.PIN, a.Subtype, b.parcel_no, b.siteaddress, b.site_citystzip, b.sw_hauler, b.sw_service_day, b.sw_str_sweep_week, a.GlobalID, a.Shape, b.own1 from dbo.parcel_polygon a left outer join dbo.ParcelWeb b on a.pin = b.pin where a.status != 'Retired' and a.status != 'Pending_Retired' and a.status != 'Pending'
Has anyone else had a similar situation or can provide any insight? Also, the reason I am wanting to use Make Query Layer is because I want to include that tool in a Model (eventually python) to run nightly updates and have the data be pushed from the resulted query layer to an SDE feature class.
Thank You
