I apologize in advance for my English.
I'm learning how to process SAR imagery in ArcGIS Pro. I have gone through the tutorial "Process Sentinel-1 SAR data" and "Explore SAR satellite imagery". Everything worked for me. So I downloaded my own actual SAR imagery to process and it keeps giving me an error when I process "Remove Thermal Noise".
I have downloaded the images either from Copernicus or from EarthData ASF. When I download the data from Copernicus, it usually won't load the "manifest.safe and tells me so:
"Failed to add data, unsupported data type. manifest.safe\Container
The system cannot find the specified object."
From EarthData ASF I can load the data. When I use the "Remove Thermal Noise" tool, it reports the following error:
Parameters
Input Radar Data IW1_manifest
Output Radar Data
\GIS ČČK\Test\IW1_manifest_TNR.crf
Polarization Bands VV;VH
Messages
Start Time: pondělí 20. května 2024 20:19:29
A raster error has occurred. The messages that follow will provide more detail.
Failed to open raster dataset [Failed to open dataset: C:\Users\snake\AppData\Local\Temp\ArcGISProTemp28516\xce166bb8_bcce_4b87_9b70_6538a6d66e5fy0.afr]
Parameter 'Raster' is missing or invalid. Bind failed in function 'Geometric Function' [Geometric Function].
Failed to open raster dataset [x30f49a15_5105_4222_8a39_a251dbf907a4y0.afr]
Failed to open raster dataset [Failed to open raster dataset]
Parameter 'Raster' is missing or invalid. Bind failed in function 'RasterInfo Function' [RasterInfo Function]. [Missing raster: [D:\GIS ČČK\Saarburg_2024-05\S1A_IW_SLC__1SDV_20240519T054253_20240519T054320_053936_068E5E_A2AB\S1A_IW_SLC__1SDV_20240519T054253_20240519T054320_053936_068E5E_A2AB.SAFE\SENTINEL1_CALIB:UNCALIB:D:\GIS ČČK\Saarburg_2024-05\S1A_IW_SLC__1SDV_20240519T054253_20240519T054320_053936_068E5E_A2AB\S1A_IW_SLC__1SDV_20240519T054253_20240519T054320_053936_068E5E_A2AB.SAFE\\\\\manifest.safe:IW1_VH:COMPLEX]]
Parameter 'Raster' is missing or invalid. Bind failed in function 'RasterInfo Function' [RasterInfo Function]. [Missing raster: [D:\GIS ČČK\Saarburg_2024-05\S1A_IW_SLC__1SDV_20240519T054253_20240519T054320_053936_068E5E_A2AB\S1A_IW_SLC__1SDV_20240519T054253_20240519T054320_053936_068E5E_A2AB.SAFE\SENTINEL1_CALIB:UNCALIB:D:\GIS ČČK\Saarburg_2024-05\S1A_IW_SLC__1SDV_20240519T054253_20240519T054320_053936_068E5E_A2AB\S1A_IW_SLC__1SDV_20240519T054253_20240519T054320_053936_068E5E_A2AB.SAFE\\\\\manifest.safe:IW1_VV:COMPLEX]]
XML document must have a top level element.
Distributing operation across 8 parallel instances.
Failed to execute (RemoveThermalNoise).
Failed at pondělí 20. května 2024 20:19:39 (Elapsed Time: 9,79 seconds)
Can anyone advise. Thank you
