I create a new feature class using ArcCatalog and then add it to my .mxd as the source. At this time, all field names are the same as the alias names.
But after I've published this feature service to the server, several of the field alias names get switched around. Please see attachment.
Is there some standard field naming conventions that I should be following? Or is there some issue with my existing field names that I've encountered?
Walter
