Hello, we have just recently set up an Enterprise system on our server. During the process, we migrated our old imagery caches which were on an ArcGIS server to a new server, the same one Enterprise is now deployed on, I am having some difficulty figuring out how to go about adding the old imagery into the Portal as basemaps, though the basemap portion should be easy enough. I am trying to avoid regenerating the imagery cache or uploading a copy of the imagery cache since they are so large and will be relatively time consuming as well as the server may not have the space to duplicate all of the imagery.
Edit: The files are in a .bundle format, so I do not seem to be able to add them by going to portal-->create tile layer-->select from a dataset in a datastore. I did set the files up as a datastore. Adding the tile package didn't work either, which I created in my earlier attempts.
Edit 2: Background, originally everything was done on ArcMap and an old version of Server, so we have a bunch of old imagery caches that were on the old server I would like to import into Portal and Server without rebuilding them through ArcGIS Pro's interface. The imagery caches are sitting on the same Amazon Server hosting also hosting Enterprise. They Server and Portal are federated.
