I have a biodiversity monitoring survey containing a repeat function. The survey captures data following a 200 metre line. The user will capture data at 10 metre intervals, resulting in 20 outcomes. The same survey can be used for the entire line. The repeat function allows the user to capture data at each location.
I have configured the survey to lock in a total of 20 repeats. If all repeats are populated, the survey is valid and can be submitted.
If the user is following protocol, they will capture data at 10m, 20m, 30m, 40m and so on. The final repeat will be at the 200m mark.
If the user needs to use a separate survey e.g. trap checks, they will save the current survey as draft and then reopen it later and continue the line. The problem is, the survey will go back to the first repeat by default. Is there any way to instruct S123 to remember the last repeat that was being captured?
For example, the worker is capturing data for repeat 15 of 20. They save as draft, reopen the survey and S123 automatically takes them back to repeat 15 of 20 (rather than 1 of 20 which it's doing currently).
Any help or advice is welcome 🙂
@DougBrowning feel free to add your 2 cents, I think you will know what I'm talking about!!
