I have an ongoing task where I need to load data into a table from an oracle database using a SQL expression.
We used to use the Simple Data Loader in ArcMap and the process worked fine, if a little slow (2-3 hours). I'm currently migrating our processes to ArcGIS Pro and have encountered a problem with the Append tool. After setting up the parameters and hitting 'Run,' the process jumps to 5% complete and then stalls. It then sits at 5% for several hours until eventually crashing Pro.
I've tried appending to data to both a table and to an empty feature class but get the same result. I've also tried using the Table-to-Table tool and got the old 'ERROR: 999999: Something unexpected cause the tool to fail' message. I'm not overly technical, but I've been trying to work out the issue and have come up empty.
Has anyone else encountered a similar problem when using the tool?
Is it something to do with trying to load data from an sde?
I thought it might have been a compatibility issue with oracle, but we have recently upgrade to 19c and the issue is still occurring.
I'm currently using Pro 2.9.11
Any thoughts or ideas are greatly appreciated!
