@JamesTedrick , @IsmaelChivite
The following describes our deployments which is based on ArcGIS Enterprise 10.8.1.
I have a Survey123 Connect survey (Survey1) which is used by our industrial staff for asset inspection. The asset inspections includes identification of any additional works (i.e. assignments).
We are planning to deploy Workforce to manage assignments, and based on the blog article at:
https://www.esri.com/arcgis-blog/products/workforce/field-mobility/workforce-survey123-creating-assignments-field/
I have set up a separate Survey123 survey (Survey2) that can be used (by our technical supervisors) to initiate new assignments (unassigned) to Workforce.
We have also deployed Power Automate, so that when 'Survey1' asset inspections are recorded that include any additional works.. then a message is sent to an MS Teams channel (potentially to alert the Workforce Dispatcher).
My question is whether its possible to use Power Automate to pass new assignments from my original survey (Survey1) to the Workforce service... if this isn't possible, I guess the alternative would be to remove the works identification from Survey1 and get our industrial staff to use Survey2 to get the new assignments into Workforce.
I note that there is some discussion around this within the community post at:
https://community.esri.com/t5/arcgis-survey123-questions/editing-multiple-feature-services-in-a-single-form/td-p/829426
that suggests that a solution may be possible.. but the post is from 2018, so perhaps there has been updates since then?
Grateful for any insights/advice.
