Hey all,
I currently have thousands of points on my map that I need to run through Network Path Planner, but before I can do that I need the separate them out by county. Doing this manually consists of Selecting by attribute selecting "Where"county" is equal to "county name" clicking apply, right clicking the feature, clicking data, then clicking export features, appending the county name to the new feature name, Clicking OK deleting the features from the old feature class then moving on to the next County Name. As you can imagine this is quite tedious. Is there a tool that can be used to iterate through this? I figured this would be a good use case for model builder but cant figure out how to get things setup in order run let alone actually iterate through each of the county names automatically. Each of the county names is located in a field called county if that helps.
Any help would be greatly appreciated.
