I am trying to do webgis restore on parallel 10.8.1 arcgis in Windows environment .
Planning to upgrade to 11.1 later from this.
I have modified /etc/hosts as recommended in esri blog.
https://www.esri.com/arcgis-blog/products/arcgis-enterprise/administration/migrate-to-a-new-machine-in-arcgis-enterprise-two/#:~:text=Steps%20to-,migrate,-distributed%20environments
Server and DataStore restore have succeded as per command line output.
But the Portal restore fails with message "Database is not running on port 7654. Please start the server before invoking this call'
I checked all the services and datastore, database are all up and running.
1) Can we only import the portal data from webgisdr backup in these types of circumstances ?
2) How do i fix the database error?
3) Any easy methods to copy the portal items to the new portal on the parallel server? or any scripts?
4) How can I change the URL of portal items to test URLs so that i can allow UAT testers to access the system.
