Hi
I am migrating from 10.8.1 to 11.1 in Windows 2019 server os in Parallel environments in HA.
This step is for migrating the data.
I am having issues with webgisdr with public portal url should be same the existing environment.
So thinking of alternative options.
Will export/import have less restrictions than webgisdr?
Will it be easier and quicker ?
If I want to export/import these 3 components from 10.8.1 to 10.8.1.
1) Does all three operations need to be done as set together or can they be imported independently ?
like eg. If I import only portal without datastore . does it have any impact?
if i import portal and datastore without server . does it have any impact? I can publish all services manually. does it work?
https://enterprise.arcgis.com/en/data-store/10.8/install/windows/data-store-utility-reference.htm#ES...
https://developers.arcgis.com/rest/enterprise-administration/server/exportsite.htm
https://developers.arcgis.com/rest/enterprise-administration/portal/export-site.htm
