I upgraded my Sandbox 10.9.1 Enteprise System to 11.1 a few months ago. Ever since I have been unable to login to Portal through the Web Adaptor becuase the sign in screen times out. The standard esri sign in dialog box will not show up. I can sign in through the port successfully. I have tried every option I can think of to get past this. The screen shot attached shows the error I always get.
1. Uninstalled every peiece of the system and re-installed
2. All esri patches installed
3. Check certificates
4. Tried logging in from differerent machines, outside and inside of networks
5. Nothing is called it in the Portal or IIS logs
5. Checked AV and Firewall
6. My load balancer has a 180 second timeout so it should be plenty of time
My other 10.9.1 systems all work normally and are setup almost exactly the same.
Windows HA setup.
