Hi all,
I'm working within an SQL Server Windows based GDB Enterprise federated with Portal for ArcGIS 10.9.1. My question is whether there is a difference between the three different ways of getting a table into Portal that affects editors working on the SDE/Default data on the SQL Server? I want to limit any effects that might slow down the technicians editing in their versions but I can't find documentation anywhere on how published data affects the underlying SDE/Default SQL GDB. Here are the three methods I have tried:
1. Publish stand alone table from ArcPro - results in a hosted layer. Has the option to be copied or referenced
2. Publish during bulk layers from Data Store process - results in a table that looks like a feature layer
3. Publish as a Map Service from ArcPro with other feature classes - results in a table that keeps it's relationship classes but is still not hosted. Can be copied or referenced
My burning questions:
- Are referenced layers causing calls to go to our SDE/Default SQL GDB and potentially slowing down editors' access to the same data?
- If we 'copy' the data to the Portal (and not choose referenced), will changes editors make on the SQL GDB automatically appear or does one then need to set up regular 'syncing'?
I am just curious as to what some other folks' are doing as part of their 'Best Practices'? Thanks!
