Hi there,
I've deployed the Cemetery Solution and have been appending data and have run into a weird issue while creating and appending data for the layers.
Going through the tasks, I created Sections, and then since our cemetery has Blocks, I would run the append tool as illustrated by the task. However, even though I was pointing to the correct Layer (the Sections layer inside the Cemeteries Hosted Feature Layer) data that was meant to append to Blocks shows in Sections instead. When I go to append to Sections, that data shows up in Blocks.
Is this by design? Am I missing something with how this Solution was set up or have others encountered this as well?
Thank you
