I have a python script that performs the following:
1) Exports csv data from a feature layer (that contains polygons and centroids that were generated from the polygons)
2) Performs some external processing on the data (this performs some logic joining original and related data that the internal feature for joining tables in arcgis can't handle, hence the need to do it externally)
3) Imports the processed csv data back into arcgis, creates a feature layer from the data, and associates the feature layer with a webmap
I'm running into an issue with step #3, where I need to recreate the centroids from the uploaded csv data, and I'm hoping I can do this in an automated fashion within the same python script.
Here's the pertinent section of the code (stripped down for readability):
def generate_points_2(params):
gis = GIS("https://fotnf.maps.arcgis.com/", "xyz", "YYYYY")
print(f"Connected to {gis.properties.portalHostname} as {gis.users.me.username}")
arcpy.AddMessage(f"Connected to {gis.properties.portalHostname} as {gis.users.me.username}")
snake_case_random = uuid.uuid1()
csv_file_orig = args.data_path / f"Joined.csv"
csv_file_new = args.data_path / f"Joined_{snake_case_random}.csv"
shutil.copy(csv_file_orig.resolve(), csv_file_new.resolve())
csv_agol = gis.content.add(item_properties={
'title': f"Test CSV polys {snake_case_random}",
}, data=csv_file_new.as_posix())
csv_agol.move(f'Oliver')
feature_layer = csv_agol.publish()
sr = 4326 # or whatever your spatial reference is
feature_layer = FeatureLayer(feature_layer['url'] + '/0')
# query features to dataframe
df = feature_layer.query(
as_df=True,
return_centroid=True,
return_geometry=False,
out_sr=sr
arcpy.AddMessage("Here 61")
# convert centroid to dict
# ordinarily I don't like long single lines, but there's no point in assigning all the intermediate outputs to their own variables
sdf = GeoAccessor.from_xy(df.join(pd.DataFrame(df.loc[:, 'centroid'].to_dict()).T), 'x', 'y', sr=sr)
But this line:
as_df=True,
out_sr=sr
)Generates the following error:
'returnCentroid' parameter is invalid
Return geometry centroid is only supported on layer with polygon geometry type.
(Error Code: 400)
I found the following suggesting for what appears to be a similar issue:
https://community.esri.com/t5/data-management-questions/import-csv-data-and-convert-to-polygon-shapefile/m-p/234948/highlight/true#M13336
But that thread is quite old (2015) so I'm wondering if that would still be the right direction to take or if there would be another, possibly simpler, approach?
