Currently, when deploying a Conservation Solution such as Wildlife Management, there is no option to change the name of the solution when it is being deployed. And you can therefore only deploy one solution per user in an organisation.
I support several protected areas and I would like to deploy several reserve specific solutions as the biodiversity/threats differ significantly between the reserves. Therefor please can you add the ability for me to provide a prefix before deploying the solution? A few months ago an ArcGIS Pro script could be used to rename the deployments from ArcGIS Pro, but that is no longer possible as the solution is now 100% deployed within ArcGIS Online.
This request may apply to several other solutions.
