2025 Exam Version – Available to Public | 2201 Exam Version – Retired |
Design - 29% | Design - 29% |
Determine the appropriate geodatabase strategy that meets defined requirements | Determine the appropriate geodatabase strategy that meets defined requirements |
Determine the appropriate data association options within a normalized data model | Determine the appropriate data association options within a normalized data model |
Determine the appropriate method to store and serve data | Determine the appropriate method to store and serve data |
Determine the correct versioning and archiving workflow | Determine the correct versioning workflow |
Determine the correct data distribution solution | Determine the correct data distribution solution using scalability and data synchronization frequency |
Configuration 23% | Configuration 22% |
Determine how to create, enable, configure, and upgrade an enterprise geodatabase | Determine how to create, enable and configure an Enterprise geodatabase |
Apply the correct data security model implementation | Determine the correct data security model implementation |
Apply the correct distributed data configuration | Determine the correct distributed data configuration |
Manage mobile data workflows | Determine the correct process to manage mobile data workflows |
| Determine the correct data backup, recovery, and retention solutions |
Loading, Transferring, and Editing 17% | Loading, Transferring, and Editing 12% |
Understand the steps involved when using different data loading and updating options | Determine the steps involved when using different data loading options |
Understand the implications of using SQL with geodatabase editing | Determine the appropriate method when using SQL with a geodatabase |
Determine the correct workflow to migrate a geodatabase | Determine the correct workflow to migrate or upgrade a geodatabase |
Maintenance, Troubleshooting, and Performance 31% | Maintenance, Troubleshooting, and Performance 38% |
Troubleshoot issues with an enterprise geodatabase (i.e., performance, data sync, versioning, etc.) | Troubleshoot performance issues with an Enterprise geodatabase |
Locate and interpret information in geodatabase system tables | Apply concepts to locate and interpret information in geodatabase system tables |
Determine the appropriate strategy to create and maintain indexes | Determine the appropriate strategy to create and maintain indexes |
Evaluate common connection or locking issues | Troubleshoot geodatabase versioning related issues |
Evaluate the application and workflow factors that affect database load and performance | Apply a strategy to administer geodatabase archiving |
| Determine how to resolve a common connection or locking issue |
| Troubleshoot distributed data synchronization issues |
| Troubleshoot advanced geodatabase functionality |
| Troubleshoot application and workflow factors that affect database load and performance |
