I'm currently trying to add a geoprocessing service to WebApp Builder in ArcGIS Online.
I followed the following steps here:
How To: Publish a Custom Print Service with Embedded Credentials from ArcGIS pro to a Stan (esri.com)
However when I add the rest endpoint for the tool into the print widget, it prompts for user credentials, even though they are embedded within the tool.
The geoprocessing service is in a standalone ArcGIS Server version 11.1, the tool was published from ArcGIS Pro 3.x.
The geoprocessing service security setting is set to private, which is why i think it prompts for login, but I would of thought that because I've embedded credentials that it would not prompt,
If I set the service security setting to public in arcgis server, the print widget works fine, however when it is set to private it prompts, is this expected behaviour? is there a way around it?
Has anyone else came across this, or been able to add a custom print service from a standalone ArcGIS Server into WebApp Builder in ArcGIS Online so users can use custom print templates/layouts.
Thanks in advance,
Kind regards
Keiran
