Hi everyone,
we are getting delayed responses from Print widget when printing the map in Web mapping application (we've downloaded the app & hosted in the IIS in windows server).
we've tried following tests to imporve the performance but no use.
- all internal layers have 31370 Coordinates systems & basemap in the 3857
- whitelisted the ArcGIS external URLs (provided by ESRI)
- removed the network firewalls & tested
- excluded the ArcGIS Server folders form the Antivirus scanning
- datastores are registered
- Printing with MAP_ONLY layout goes fast (<10 seconds)
This includes the base map and our layers. This allows us to exclude the loading of the external datasource as potential problem - Printing in A4 Portrait goes slow
The main difference between both seems to be the legend. - When we deactivate the legend in the printing (A4 portrait, but also other formats), we get the result in less than 10 seconds. When we activate the legend, we have the result after 40 seconds or more.
We are using ArcGIS enterprise 11.0 with SQL Server DB. We have downloaded the web map application and hosted in the IIS webserver.
If the above info is sufficient to help us , Kindly provide any workaround /solution to improve the performance of the Print widget.
Regards
GIS Functional Group
