Hello everybody,
Background info: My popup button is a code to open and edit the existing point with inbox method they click on and will pass over / filter by address. It works no problem online, but the filter function does not seem to work with the inbox offline, after I click the popup button offline it opens survey123 form without the exact feature from field maps and then generates "error 0". Here is my code , any thoughts? I definitely need this workflow to work offline.. Both my web map is offline downloadable, no issues and the survey itself with feature layer. Full editing access with update, add, and delete.
TESTING THIS FOR OFFLINE
Currently instructing them to "Refresh inbox" and solely use S123 for offline usage, but limits them from using the map pop up method like online..
<p><a href="arcgis-survey123://?itemID=14505fc4d195405aa06de1ee200a8e9e&action=edit&folder=inbox&update=true&filter={address}"><img class="image_resized" style="width:54.83%;" src="https://dabuttonfactory.com/button.png?t=Service+Line+Survey&f=Roboto-Bold&ts=22&tc=fff&tshs=1&tshc=000&hp=20&vp=8&c=5&bgt=gradient&bgc=6aa84f&ebgc=274e13&shs=1&shc=444&sho=s" alt="Service Line Survey"></a> <span style="color:#ffffff;font-size:large;"><font style="background-color:rgb(220, 20, 60);"><strong>{expression/expr3}</strong></font></span><span style="color:#000000;font-size:large;"><font style="background-color:rgb(255, 215, 0);"><strong>{expression/expr5}</strong></font></span><span style="color:#ffffff;font-size:large;"><font style="background-color:rgb(128, 128, 128);"><strong>{expression/expr4}</strong></font></span><span style="background-color:rgb(65,105,225);color:#ffffff;font-size:large;"><strong>{expression/expr6}</strong></span></p>
NOTE: I am currently relying on the q:GlobalID={GlobalID} passover for online workflow, trying to update with offline workflow with the filter and refresh inbox option.. explained by @JamesTedrick https://community.esri.com/t5/arcgis-survey123-questions/open-specific-survey-in-survey123-inbox-from/td-p/1161524
My working online code... using q:Global IS BELOW
<p>
<a href="arcgis-survey123://?itemID=14505fc4d195405aa06de1ee200a8e9e&action=edit&folder=inbox&update=true&q:GlobalID={GlobalID}"><img class="image_resized" style="width:54.83%;" src=" https://dabuttonfactory.com/button.png?t=Service+Line+Survey&f=Roboto-Bold&ts=22&tc=fff&tshs=1&tshc=000&hp=20&vp=8&c=5&bgt=gradient&bgc=6aa84f&ebgc=274e13&shs=1&shc=444&sho=s" alt="Service Line Survey"></a> <span style="color:#ffffff;font-size:large;"><font style="background-color:rgb(220, 20, 60);"><strong>{expression/expr3}</strong></font></span><span style="color:#000000;font-size:large;"><font style="background-color:rgb(255, 215, 0);"><strong>{expression/expr5}</strong></font></span><span style="color:#ffffff;font-size:large;"><font style="background-color:rgb(128, 128, 128);"><strong>{expression/expr4}</strong></font></span><span style="background-color:rgb(65,105,225);color:#ffffff;font-size:large;"><strong>{expression/expr6}</strong></span></p>
