I am Using ArcGIS Pro 3.1.0 with the Data Reviewer add on license.
I have created a map with two polygon layers that I want to use in the Data Reviewer Error Inspector by using one to check the other. Basically I want to see if their polygon extents line up with the postcode/zipcode polygons that their postcode field references, using the validation - feature on feature rule from the ready to use rules.
My map, and every layer within it (including the basemap) is in the same spatial reference (British National Grid), but when I create the Error Layers (right click the layer> Add Error Layers) and look at the spatial reference, it states that the error layers are in WGS84. Running the Evaluate Rules in Error inspector shows the Error layers offset to the two polygon layers I already have on the map.
Any idea as to rectify this so that the Error layers appear in the same spatial reference as the source data, so I can run the error inspector and get the Error Inspector to run properly?
