Hello everyone,
I'm trying to use ArcGIS enterprise with enterprise geodatabase (versionning, bulk publish in portal). To do that, first I have import the sde configuration file to ArcGIS Portal and then, I follow the procedure to publish all the layers of the database into a bulk process.
I'm using ArcGIS Pro to edit and draw maps but I would like to create specific maps in ArcGIS Portal with some feature layers. Unfortunately, when I open the feature layers into a new map, the symbology defined in ArcGIS Pro is not saved. Is there a possibility to export this symbology so during the bulk publish the symbology is not forgotten ? Or should I simply make the maps into ArcGIS Pro and then published the map ?
Which approach is the best ? For some maps, reading would be enough but for others, I would need to edit the layers.
