Regarding tables that have been added to the map/Contents pane:
In the attribute table, could we have the option of opening a table's properties by right-clicking on the table name tab?
Video:
That would give us a way to view the table's source directly from the attribute table — for cases when multiple tables with the same name (but different sources) are open in the attribute table. For example, if I have a main.RoadInspTable open from mobile geodatabase 1. And a table with exactly the same name open from mobile geodatabase 2. How to know what table you're editing, etc.?
Yes, we could close the tables, then re-open them from the Contents pane, and mentally keep track of which is which. But it might be better to determine the table's source directly from the attribute table.
There are comments about this idea in Visible path for open table [table not in Contents].
