Hi:
I'm working with lidar to profile vegetation in the 1 - 4 meter class. When I use the Classify by Height tool on the LASD, I get an error: "ERROR 050157: Failed to process the LAS Dataset" and the reason given is "Class not registered." However, when I go through each LAS individually, the tool works fine.
There's a solution referenced from 2016 but I'm not quite clear on how to do it or if it's applicable to my problem:
Error: Class not registered (esri.com)
Memory is hazy but the problem might (?!) have started when I cloned my old SSD "C" drive to a newer M.2 drive. In any event, classifying by height tool has worked for me in the past but all recent runs have gotten this error message.
Thanks for any help anyone here can give!
George
