I am using Armap 10.8.2 and my issue is the result obtained from the path distance tool.
it appears a warning massage stating: Cost Cells with zero or negative values were encountered. Not all source cells may have been processed.
The used data are:
-shp point as origin;
-DTM (used as surface raster and vertical surface input);
-Slpoe (used as cost raster).
I used to process the same data in Arcmap 10 and I've never had this problem.
How can I fix it?
I attached an image of the result.
Thank you in advance @DanPatterson
