Hi Community,
Hope everyone is doing well
I just want to make sure that I am following the correct workflow. We are in the process of installing geoevent server on a machine which is separate from the machine where we have our base deployment set-up.
Our base deployment is fully functional and is configured with a CA signed certificate. In order to configure ssl certificate on geoevent server I referred to the following documentations:
- https://enterprise.arcgis.com/en/geoevent/10.9.1/install/windows/optional-self-signed-certificate.htm
- https://enterprise.arcgis.com/en/server/10.9.1/administer/windows/configuring-https-using-an-existing-ssl-certificate.htm
After going through the documentations I think I need to take following steps:
- Export the CA certificate by giving password from IIS in .pfx format.
- Navigate to the admin end point of ArcGIS Server underneath which Geoevent server would be running and import the certificate.
Please let me know if any additional steps needs to be taken.
