Hi all,
TLDR: Can I return to the editing mode of my arcade expression (in visualisation tab of a feature layer view) to confirm the configuration has been committed?
Context to the symbology arcade expression:
My data updates as indicated as an incremental release number. I don't want to filter by a discrete value, trying to avoid additional portal config steps. So instead I use the Max arcade function to return(and visualise) only the highest release number.
Steps taken:
1. In my feature layer view, I edit the symbology based on a Max arcade expression for a release number attribute (numeric).
2. I update feature layer with rows corresponding to the most recent release
3. When I return to the feature layer view I *think* I see my desired map view and click around many many grids looking for the right release number.
4. Sometimes the expression doesn't seem to be committed/saved and I have to set up the symbology expression again, and sometimes it works as planned.
5. To perform QA, I would like to confirm the configuration has committed, but I cannot return to the expression I made in step 1. Returning to the visualisation feature starts the whole process again...
Please help explain why I can't return to view the expression, have I missed a step? Have I missed a best practice around QAing portal configuration, have I made the mistake of putting too much value on the arcade symbology based configuration that can't be viewed once set?
Kind regards,
Nina
