I'm creating a survey in Survey123 Connect which contains a select multiple question type. I'm using numeric codes for the choice names and standard text labels for the front end selection. I'd like to have these labels returned within a hidden text field so I can then view the labels instead of the codes for future use in dashboards or other apps. I'm using this calculation expression
jr:choice-name(selected-at(${layerlist}, 1), '${layerlist}')
found via this post - https://community.esri.com/t5/arcgis-survey123-questions/select-multiple-list-no-save-label/td-p/1138198
I noticed that there is a choice index number within the expressions which specifies which selection to return. I would like to return all of the select multiple selections and not just a single choice. Is it possible to return all of the choices? If so what would I input in the choice index section of the expression? Any help is appreciated.
