Just upgraded a single machine base deployment from 10.7.1 to 10.9.1. Everything was successful, but I receive the following error message when attempting to validate the federated server
- Error: Unable to validate TLS certificate on ArcGIS Server administration URL. Ensure the root certificate is trusted or the certificate common name matches the URL hostname.
I am using the exact same certificate that was being used without issue before the upgrade. I confirmed the root is trusted on the machine, and it is a wildcard cert so the 3rd part of the of the error message does not apply.
Why would 10.9.1 not like this cert if it was valid for 10.7? is there another step I am missing to complete the federated server validation process after an upgrade?
I am able to access server admin, portal admin, and portal home without issue, but server manager will not load after the sign in page.
