I created an ETL tool, that works fine locally, but after publishing it to our portal my scripted user parameters do not work.
The reason for it:
INFORM: Python version 3.8 loaded successfully
ERROR : Python Exception <ModuleNotFoundError>: No module named 'arcpy'
My scripted user parameters are essentially in place to create and write the output of the tool into scratch workspaces. While I am working for several years now with FME, this is my first time creating and publishing an ETL tool. Hence, I am not so familiar with possible automatic path adjustments when publishing tools.
Question 1: So, could it be that I can simply keep the writers destination as an absolute (local) path and when publishing it to our portal the destination path will be pointed to a scratch location?
Question 2: How can it be that I publish something to an ArcGIS Enterprise Portal and that portal is not aware of a module called 'arcpy'?
