My goal is to have a geofence in the portal (as a layer) , that can be edited with the editor widget from ArcGIS API, that at the same time can be imported as a geofence in GeoEvent to work as a real time geotrigger.
So far I have published a feature layer from ArcGIS Pro to my Enterprise portal that contains a Polygon layer. I wish to import this feature/polygon layer as a geofence in GeoEvent. However, when selecting the feature layer as Service in GeoEvent, the polygon layer cannot be selected as the Layer for the GeoFence and I fail to import this.
Is there a way to make this work? I have not found a way to import anything from the portal as a geofence in GeoEvent. How do I import a geofence to GeoEvent?
Thank you in advance for any help or suggestions.
