Hello, I am getting an error when attempting to upload recordings from the IPS Setup app (iOS) to my ArcGIS Enterprise (10.9.1). I have tried both sharing a web map copying all data into a editable hosted feature layer and also containing an editable feature service referencing registered data in an enterprise geodatabase. In both cases, the feature service is editable and I can manually create records in the ips_* tables using ArcGIS Pro. I've used ArcGIS Pro 2.9.3 to share the web map. I've tried the upload connected to both 5G and corporate Wi-Fi and neither work.
In the setup app, all of my recordings have the failed to upload icon next to them. When I attempt an upload, I get the following error in the ArcGIS Server logs:
| WARNING | Jun 21, 2022, 10:09:04 AM | Error performing upload operation, File size or type not supported for this service | Rest |
Any idea what might be causing this issue? Thanks in advance!
