Hello! I'm prototyping with Field Maps/S123, specifically right now we are looking to support the user story of having a need to see a web map which shows the direction of the viewer when creating a point/photo.
Regardless of which field app we use, the requirement is still to use a field within the data to capture the azimuth which can be used to display the arrow symbol to point in a direction on the web map/app/printed maps. This function is working great in our Portal web map until you move to the next layer and that option is not available for some reason??? What I am seeing is inconsistent ability to use this feature and it's driving me crazy because I just want to understand WHY this happens. Ack!
For example: I have a Feature service with three layers. All points with attachments from the same service. Layer in Position 0 has this function available, but the other two layers (1,2) do not have this option even displayed in the UI. Is it something I did when publishing, or the underlying features in the SDE that are referenced, system limitation? I'm stumped. See attached examples.
Enterprise 10.8.1
