Hello all,
I have a las file from a sUAS flight that fails to classify anything as ground. Running the standard or aggressive ground classification returns everything still unclassified. I can manually classify everything as it's a small enough project but would like to understand what I am doing wrong. Can a las file be locked in some fashion?
The las, tif and prj (local projection) can be found in https://gis.gilacountyaz.gov/webdata/RGLF19May2022.zip if you would like to see the data. At ~860m it's a bit too big to attach. The data defects in the lower right corner is me flying too low over the adjacent landfill cell (that I am not concerned about) to get adequate overlap for processing.
Thanks for any help/advice you can provide.
Regards,
Tom
