I recently published a traditional ArcGIS Server map service from ArcGIS Pro. There was an existing service that I overwrote, but I utilized a different Pro project file for publishing.
I received a message stating that the web layer successfully published. However, when I viewed the folder in Portal with the published map service (Map Image Layer), I could see the updated map service (Map Image Layer) as well as a new map service (Map Image Layer) with the same name, but with time/date stamp added. See attached screen capture.
Publishing from ArcGIS Pro 2.9
Publishing to ArcGIS Enterprise 10.7.1
Data is sourced from an SDE GeoDB and the SDE connection is a valid data store within ArcGIS Server Manager.
Does anyone have experience with this behavior?
Any thoughts on what causes it?
How big of an issue is it/Is it bad?
