I am setting up a new PostgreSQL database with SDE and loading data however I'm running into an error saying that my database schema and username don't match. Here's the workflow.
- Stand up a database and deploy SDE on top of it as per the documentation. Running PostgreSQL 13.3, POSTGIS 3.1, and the latest version of Pro. At this point I have two accounts.
- I create a data owner account using the Create Database User tool in Pro (when logged in as SDE).
- In Pro using a DB connection as bob_smith I import a schema with data via an XML file.
- The process errors out (dreaded 999999) saying that the schema and the database user and the schema do not match.
- I check PgAdmin and confirm that the data owner account I created has a schema in that database.
- I check my connection in Pro and confirm that I'm accessing that database correctly as the data owner bob_smith.
- Stare at ceiling and scream.
I do not have a DBA background but am a GIS admin teaching himself how to administer PostgreSQL. I have another database machine with the same software versions where the workflow above worked without issue. I could easily blow away the database and users and re-create the whole thing but that does nothing to show me what the problem is and how to address it.
Any help would be appreciated.
