When I try the tabulate area tool with my raster I get the following error:
ERROR 000864 Input raster or feature zone data: The input is not within the defined domain.
ERROR 000969: The input raster is not integer type.
I have tried using the raster calculator to multiply values by 1000 - which did not work I got the same error as above. Then I tried using the Int tool to change to integer and it changed all of the values to 0... This seems like it would be a common GIS task but can't find an answer in user forums. See capture but values there are x1000.
What I want is the total area in each value range: green, red, yellow, orange, etc...
