Using Enterprise 10.9.1, I have published both a hosted feature layer and a view layer. The view layer has a filter set on it, but when I share them with our Open Data site, both layers are returning the entire feature set. Is this expected behavior?
Here is the Portal item for the view layer: https://gis.anaheim.net/portal/home/item.html?id=83e440657ab0417aa39a01efa85628d9
If you view the Data tab, you will see around 300 features.
Here is the REST endpoint for the view layer: https://gis.anaheim.net/server/rest/services/Hosted/BusinessLicenses_New/FeatureServer/0
If you run a REST query, it returns more than 1,000 features.
I would have expected a filter/definition query on a view layer to be honored through a REST query as well as the Portal item.
