When writing Arcade scripts, I think it would be helpful to do testing in an IDE beforehand, if the script doesn't use any Arcade-specific functions (or if it does, temporarily remove/fake out those parts).
For example, define a polyline array manually...
var paths = [[[0,5,null],[10,10, null],[30,0, null],[50,10, null],[60,10, null]]]
...loop through the vertices, do some stuff, and output results as text.
So, I want to use VS code to do that testing...by running the Arcade expression as if it were JavaScript . I know Arcade isn't the same thing as JS, but I think it's close enough for the testing I want to do.
Question:
Has anyone had any success running basic JS scripts in VS Code? That might be a dumb question, but I really have no idea where to start.
Unlike Python, it doesn't seem like you can just type some JS like console.log('Hello World'); and then run the code to output some text.
I tried searching the web and I got a bunch of results about node.js -- which I have installed. Unfortunately, I still can't figure out how run a basic script, such as print "Hello World".
Would someone be able to point me in the right direction?
Thanks.
