Hello everyone,
So I'm evaluating the use of the Suitability Modeler for a site selection project we have going on and am wondering if there is a way to model a negative influence.
For example, our client has identified hazardous environmental setbacks that they want to have an active, negative influence in the process.
My understanding is that the values in the "Suitability" column of the Transformation Pane are limited by whichever Suitability Scale was chosen in the Settings panel. None of these settings include negative ranges, which makes sense on a 'final output' level, but as it is right now the only way I see to model a negative influence at a parameter level is to pick a wide enough range (I'm using 1 to 10) that'll allow me breathing room in the upper numbers while any negative factors would be 'floored' to a value of 2 (I'm using 1 as the bottom 'NoData' values).
Is this correct? Is there no way to actively model detriment other than to set the values as 'not as good but still within a positive scale'?
I guess I understand the logic that that might be sufficient on a conceptual level, but in my conversations with the client they feel that there's a difference between including an active, negative influence at a parameter level and having to 'dilute' that factor due to a scale constraint.
I know that this could be handled if I programmed some raster math processes on my end, but yeah, we were hoping we could use the Modeler as an 'out of the box' solution.
Thanks!
