We are using the Maps->AddLayerFromWeb referencing a csv file from onedrive and it fails with error
"The layer was not created because no locations could be found. Make sure your data has valid location information."
The URL's we are using shows the file correctly when pasted in a browser.
SharePoint and DropBox URL's produce the same results.
The csv file can be dropped into a map and works correctly so the file appears correct. Latitude and longitude are provided. Any ideas on what is failing?
