Hi, I have a lot of repeats in my Survey, which are creating around 350 fields in related tables. Those I need to show in a ArcGIS dahsboard, however related tables don't work that well, if at all in a dashboard.
So I'm using the pull data functionality from a JavaScript (https://community.esri.com/t5/arcgis-survey123-blog/extending-survey123-smart-forms-with-custom-js/ba-p/898782 )
I tested that it workd with 5 fields, and then mass produced the required JavaScript and pulldata fields with a script to avoid typos.
When I try to run it, in the webform, I get an Oh snap! in Google Chrome, after a couple of seconds of viewing the Survey.
This Seems to work up to 47 fields/pulldata but on 48 it fails.
Any Ideas on this, either the limitation of 47 or another way to get the data into a Dashboard? I'm using 3.13
