Hello all,
Seeking the most efficient way to export an elevation profile (IE "slice" from DEM or similar), into an application such as autocad or illustrator (IE for use as an architectural drawing that is accurate reflection of the ground surface). I'm aware of the outputs of the elevation profile tool, but there doesn't seem to be a way to constrain the aspect ratio or make the vertical/horizontal units display without some distortion/vertical exaggeration (IE when you scale the viewing window it scales the graph too). Seems like this process should be simple, maybe I'm missing something?
