We have enterprise 10.6.1 single machine deployment (windows). ArcGIS Pro 2.7 is installed on same EC2 instance Portal/Server are installed on. I am attempting to do the following:
- GP Initiated through REST service call
- GP calls a batch file through python SubProcess (import subprocess and popen method) like so:
p = Popen([matrix_run_bat], stdout=PIPE, stderr=PIPE)
p.wait()
output, errors = p.communicate()
print([p.returncode, errors, output])
arcpy.AddMessage([p.returncode, errors, output])
if p.returncode or errors:
print('something went wrong...')
arcpy.AddMessage('something went wrong...{0}, {1}'.format(errors, output))
3. The batch file triggers another python file using ArcGIS Pro Python like :
<a href="https://community.esri.com/t5/user/viewprofilepage/user-id/464769">@echo</a> Starting Telr Matrix
call "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3-clone-telr-matrix\python" "D:\2nform\TELR_GRID\Pat_Dev\telr-matrix\main.py" "run_telr_matrix" 10 2021
@echo Finished
The python env in first argument of the bat file is a clone in my ArcGIS Pro env. The error I get when running gp service is that a module (that I know has been installed in the bat specified python env) in main.py is missing:
esriJobMessageTypeInformative: something went wrong...b'Traceback (most recent call last):\r\n File "D:\\2nform\\TELR_GRID\\Pat_Dev\\telr-matrix\\main.py", line 3, in <module>\r\n from telr_matrix.run_telr_matrix import RunTelrMatrix\r\n File "D:\\2nform\\TELR_GRID\\Pat_Dev\\telr-matrix\\telr_matrix\\run_telr_matrix.py", line 4, in <module>\r\n from telr_matrix.cbmp.cbmp import CBMP\r\n File "D:\\2nform\\TELR_GRID\\Pat_Dev\\telr-matrix\\telr_matrix\\cbmp\\cbmp.py", line 5, in <module>\r\n import geopandas as gpd\r\nModuleNotFoundError: No module named \'geopandas\'\r\n', b'Starting Telr Matrix\r\n\r\nC:\\Program Files\\ArcGIS\\Server\\framework\\runtime\\jre\\bin>call "C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3-clone-telr-matrix\\python.exe" "D:\\2nform\\TELR_GRID\\Pat_Dev\\telr-matrix\\main.py" "run_telr_matrix" 10 2021 \r\nFinished\r\n'
It looks as if it is still attempting to run the python script using the 10.6.1 Server python version instead of the ArcGIS Pro python specified in bat file. When I run subprocess locally from a variety of default python env, it will use the correct env specified in the bat call.
And just FYI, the reason I want to use the ArcGIS Pro env and not update the default Server 10.6.1 env for the gp task is because of this ominous bit about updating module in default server env at 10.6.1:
You will be modifying the defaultArcGIS Serverconda environment. In the event of environment corruption, you will need to re-install yourArcGIS Server. If you are usingArcGIS Server10.7 or later, a safer process to deploy your Python packages is available.
So, should it be possible to call ArcGIS Pro Python from ArcGIS Server 10.6.1 python gp service using a subprocess that runs a bat script that specifies to use ArcGIS Pro Python? Thanks!
