I am using ArcGIS Pro 2.8.1 on Dell Mobile workstation with Windows 10 installed in it. I saved my data in the geodatabase which resided in external drive (WD usb 3). It saved well, I exited the program. When I try to reopen the geodatabase, it throws an error of "The parameter is incorrect." The folder on which the geodatabase exists still taking space. So, I used "arcgisbinding" package from R to check if it works. It did work with GDAL Error 1. However, my last saved feature classes are no longer there in the geodatabase, or at least, feature listing using ogrListLayers function didn't display all the layers.
This happened to me second time within 10 days. Any help on this error either solution or sharing your problem would be great!
Thanks!
