I updated our enterprise server (single server deployment) from 10.7.1 to 10.8.1 including the Server and Portal applications.
Now, I am only able to login to the Portal site via the local access URL (port 7443) on the server. If I try to login using the FQDN on a different machine (as I would to use it from my desktop), I get kicked back to the Login screen. This happens whether I login using the site admin account or an enterprise user account.
I am able to login to the server manager, but Portal does not work. The server license appears to be valid and applied correctly.
I did notice that the local management port uses a self-signed certificate, whereas the normal login is using our CA signed certificate. I'm not sure if that is related or not though.
Are there any steps I've overlooked in this process?
