Hello, S123 Community,
I'm using S123 Connect v. 3.12.232
Our field folks like using the numbers keyboard for integer and decimal questions better than their device keyboards. I know that there was a big push to add the return key to the numbers keypad so that it would advance the cursor to the next question.
The problem for our surveys is that this advancing skips over select_one questions, and even entire repeat sections if there are no text type fields for the cursor to land in.
According to this thread: https://community.esri.com/t5/arcgis-survey123-questions/advancing-to-next-question-using-return-key-on-device-keyboard/td-p/843144 the "input" type questions should take focus "by the tab or return key", which I believe in that thread is referring to keys on the device keyboard, not the in-survey keyboards. It lists select_one as one of the "input" types that will take focus from those keys.
Is there a way to either include select_one questions in the group that will take focus from the numbers keypad return key, or disable that return key so that the user has to navigate manually through the survey? Not as efficient, but better than missing questions.
Erica
