First off, we are currently using 2.6 and hope to go to 2.7 or 2.8 soon, and maybe this has already been addressed, but I did not see any other comments/ideas out here regarding this.
I edit a lot, and I need to see how many & what all are selected. Not always easy to tell by just looking. I also like to see listed what I have selected, because sometime I forget I had the points or another feature still selected, which I do not want to accidently delete or move.
In ArcMap, the List by Selection window could be narrowed and you could still see the count. ArcMap would also move up in the window, the layers that were selectable, so you could easily see what was turned on for you to select. Very easy and helpful window.
In ArcGIS Pro, if you narrow the window, so you have wider editing map window, you can't see the count anymore to tell if you have something selected. List by Selection window has to be really large to see count. Also, nothing is clearly noted or move up in the window to tell what all is turn on for selection. This is not very helpful window to easily see what is selectable. Also, it is very frustrating having to enlarge the window to see count and then narrow so you have a larger editing map window.
Please see attached screenshot comparisons. Any help for future improvement would be great!
Thanks, Cathy
