I had a related inspection table to a sewer line feature class. I defined a view to join these so as to symbolize on attributes in the related table. The view broke when I added another field to the sewer line feature class. I defined it as * to bring all featureclass fields in so that is curious it breaks. Simply copy and pasting the exact same SQL view back into Catalog to create it again, it works fine. So some internal stuff must get saved and hard coded at the creation time of the view in Catalog and adding a field breaks it. I could understand removing a field but not why adding one would break it. If this is expected behavior I suggest allowing new fields to be added to FCs in a View. It would be useful because views are often powering web services as this one was.
