What is the most appropriate health check configuration for ArcGIS Server when using an application load balancer in AWS?
The default guidance from Esri (e.g. cfn scripts) is to use the 6443:/arcgis/rest/info/healthCheck endpoint. However this does not take into consideration the web adaptor or issues within the web adaptor / web server tier.
Another option would be to use the same endpoint but from :443/webadaptorName/rest/info/healthCheck. However, even if the healthCheck endpoint returns a broken response it is still code 200 and healthy.
What would be the best option? I was thinking an export request against sampleWorldCities.
