I am experiencing problems to Register table and/or view created in third-party SQL client (underlying DBMS is Oracle).
The register tool requires ObjectID field only for view which has to be integer:
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/register-a-table-or-view-with-the-geodatabase.htm
To register a table, an ObjectID field is not compulsory.
In my view, I created a not null, no identical ObjectID field using a CAST( as integer) limited to 4 bytes (up to 10 digits) to comply with this technical issue:
https://support.esri.com/en/technical-article/000010398
The ObjectID field is matched to LONG in ArcGIS. It looks ok.
However, it always fails to register such table and/or view and I receive the "unexpected error... The view's registered base layer was not found." It does not make sense and I remembered registering table and/or view still recently. For info, I am the table and/or view Owner.
On the other hand, if I copy & paste this table in the ESRI environment (Catalog), it automatically registers (meaning the table is valid for registration).
Any help really appreciated.
